g73M1u
Lichuang panel printing | SAKANA~
Draw 10 sets of finished products (ended)
https://t.bilibili.com/708395486317379608?spm_id_from=333.999.0.0
If digital voice is played suddenly, it means that it is too sensitive and switched to the internal space of the chip. The 1.4K resistor should be changed to 1.5K, or the 22uf capacitor should be changed to 10uf.
Introduction:
It can be used after welding, and no burning is required. No software driver needs to be installed.
Use Lichuang panel printing service. You can get 4 stand cards at a time. The board thickness is 1.5mm. The single character stand card is 100X100mm, which is larger than Taobao. The file is in the professional version editor. Click the order button to place an order directly. https://dos.szlcsc.com/
Use Taobao's cost-effective audio playback chip (CH8001)
100mah lithium battery, USB & battery automatically switch power supply, with music switch to avoid social death
External FLASH, plug in USB to simulate U disk to update audio conveniently, only one USB line can also be used as a player
Because of the built-in direct push function, the sound quality is very good, you can draw the board and install the power amplifier chip to use the DAC output mode
Demonstration video: https://www.bilibili.com/video/BV1uN4y1K7j4/
Assembly & welding instructions
Use 2 pieces of the circular bottom plate under the character stand and stack them together, then fix them on the rocking spring with UV glue to
make a The printed magnetic cover needs to be equipped with 3 magnets to attract
the PCB of the rocking spring. Use 2 self-tapping screws to fix
the middleware. Pay attention to the direction
when installing the shell. The first installation of the assembly will be very tight. After several disassembly and assembly, it will gradually become loose. Then install the PCB, battery and speaker.
The welding patch is not resistant to high temperature and is easy to break. It is necessary to pay attention to the temperature not being too high for too long, within 300 degrees for 1 second.
Special materials :
voice chip CH8001
rocking spring
self-tapping screw M1.2x4
lithium battery 401119
vibration switch
Φ20 speaker
Φ8 thick 2mm magnet, no other special requirements, buy it at will.
Printing instructions
FDM: The printing middleware cannot have elephant feet. If there are any, they need to be polished off.
Because the printing effects of different printers and different brands of materials are slightly different, two assembly gaps of tight and loose are made. Print tight first. If it is still very loose after printing, increase the extrusion amount.
Light curing:
        I haven't tried it yet, but I feel that it should be printed with tight assembly.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 06:30:31
