ICprZqSe
Rns
RP2040 To Switch learning board reduces the overall size of the PCB board (length: 14mm, width: 8mm), and the component packaging is basically designed using 0201.
![Real object welding TOP side] ![RP2040T.jpg] **TOP side welding**
![Real object welding BOT side] ![RP2040B.jpg] BOT side welding
![PCB 3D simulation and dimensional drawing] **Wiring I/ O port definition**
![PCB board size] **Dimensional diagram**
![CPU surface patch position] **CPU surface patch position**
![Peripheral component patch position] **Peripheral component patch position* *
![Welding diagram] **Welding diagram**
![Start-up test] **Start-up demonstration effect test**
At this point, the entire project has been fully tested. If any students need to learn welding and debugging, they can directly use the final version. Project proofing is enough.
PS: This subsequent version will not be modified and will be designated as the final version.
参考设计图片
Design Files
Search Datasheet?
Forum More
Update:2025-08-04 04:11:16
