AUmbv
ultimaker2 (UM2) original 3D printing motherboard upgraded silent driver extended version
# The solution has been verified
#### (board making + welding + machine installation)
![IMG20230612205336.jpg] ## The silent driver extension originally used for UM2 motherboard
supports tmc2208, tmc2209, tmc2225 and other silent drivers. Note: the steps of different drivers The subdivision jumpers are different (MS1 and MS2 correspond to jumper modes).
## Connect the flying wire to the motherboard
through a 16pin horn socket and solder the corresponding test point of the um2 motherboard (see the PDF file in the attachment for details).
### It can also be used as a driver board for a 6-stepper motor
. ### It can also be used as an expansion board for a closed-loop stepper motor
. The 6PIN interface corresponding to each axis on the above board can be used for the plug of the closed-loop stepper motor. You can search on Taobao for details.
# Existing problem
## If the printing temperature rises for a long time, it will cause loss of steps
### It is necessary to add a fan to dissipate heat, and the silent driver has a heating problem
Note: The original file was drawn by AD (in the attachment)
![ZJ%YFAD_SLWEB $~5W3P5E@B.png]
参考设计图片
Search Datasheet?
Forum More
Update:2025-06-24 11:28:41
