Vgv667
【Electronic Competition】Sync BUCK module
Circuit analysis
The synchronous BUCK circuit is shown in the figure below. The relationship between the output voltage Vo, the input voltage Vin, and the duty cycle D of the input PWM is: Vo=Vin×D.
Choose a large capacitor, 1000uF is enough.
The relationship between the inductor L and the frequency of PWM (switching frequency) is shown in Equation 1, where Vo is the output voltage, D is the duty cycle, △iL is the inductor current fluctuation, and the selection of the inductor L needs to be greater than the calculated Lmin. The PWM frequency used in this module is 100kHz level, and a 47uH inductor is selected.
The schematic diagram shows that
since I connected the HIN and LIN ports of IR2103 together and only connected one PWM input port, the output HO and LO port outputs are complementary, which just meets the switching conditions of the two MOS tubes in the synchronous BUCK.
Just connect the PWM port to the IO port of your microcontroller, and the frequency should be 100kHz.
Maximum Vdss of MOS tube: 100V, maximum overcurrent: 33A.
Driver chip IR2103 power supply: 10-20V
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-15 07:25:35
