8s36qS
ESP12F Minimal System Board
The verification board has a user LED and a button on the board, which can be connected to adjacent PINs with jumper caps or other PINs with Dupont wires;
the WIFI antenna flies out of the board, and the measured signal transmission distance is farther than that of D1 Mini. It can be separated by one indoor Block the wall;
LDO uses ME6206A, which has strong load stability, low static power consumption, and low price. It uses SOT-89 package to increase the flow to power external devices;
although the impedance of the USB signal line is not strictly controlled, there is no via hole due to the short wiring , it is guaranteed that there will be no problem with the signal.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-06 01:50:37
