GnMFOUI
LM317 regulated power supply
LM317 regulated power supply with protection function. The input voltage is DC 36V. The output voltage can be controlled by adjusting the adjustable resistor R3. The output voltage is between 30V and 6V. If the output voltage is only required to be lower than 20V, Jianyi lowers the input voltage first to avoid The LM317 should bear the excessive voltage drop and at the same time do a good job in heat dissipation of the LM317. .
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 03:09:54
