MartinFowler
2000W thyristor speed regulator module
Connect this product in series to the circuit of a desk lamp or electrical appliance (i.e. disconnect either live or neutral wire from the desk lamp or electrical appliance, and connect the two wires of this "product") Rotary potentiometer The rotating rod can play the role of light and dark adjustment, speed adjustment, voltage adjustment, and temperature adjustment; it is very convenient to use.
This product is suitable for: using new two-way high-power thyristor, because the current can reach 25 amps, which is a good solution The resistance of the electric furnace wire is too small when cooling, causing overcurrent problems; it can easily adjust the output voltage of the mains power, and adjust it arbitrarily between 90 and 220 volts for use by electrical appliances.
Such as: electric stove, water heater heat adjustment, lamp dimming, small motor speed adjustment, electric soldering iron temperature adjustment, etc. Thus achieving the effect of dimming, temperature and voltage regulation. It can be used for large electrical appliances with power consumption less than 2000 watts. Since the power is already very large, it is sufficient for general household appliances or small factories. (The power of inductive or capacitive loads should be reduced. This voltage regulator is equipped with a two-way high-power thyristor, and the potentiometers are equipped with nuts. It can be used without adding any components. It is very convenient and practical)
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 03:09:44
