vSHof20
STC8G extended version_temperature and humidity expansion module
STC8G series expansion board: Temperature and humidity expansion module. This module uses the DHT11 series temperature and humidity sensor. There are reserved interfaces on the board and the on-board buzzer can be used for reminders.
The actual picture is as follows:
Expansion board description:
The expansion board is connected to the main control board through a cable to achieve expansion functions. The cable definition is as follows:
Among them: P5.5 pin is connected to an external buzzer, and high-level input sounds, P5 .4Connect the sensor data input pin.
Search Datasheet?
Forum More
Update:2025-08-09 03:10:05
