zsvpMYvnM
lm2596 universal fixed voltage/adjustable
For buck modules made with the solid capacitors and magnetic beads that are readily available, you can use the in-line adjustable lm2596s and the in-line fixed voltage lm2596s. You can also use the TO-263-5 patch lm2596 adjustable/fixed voltage. The inductance value corresponding to which chip is used is marked on the PCB.
It has been tested with an electronic load and the output can reach up to 3A (requires heat dissipation, it is very hot). Here
are some test pictures.
The oscilloscope in the picture below was measured in front of the magnetic bead.
参考设计图片
Design Files
Search Datasheet?
Forum More
Update:2025-07-02 13:35:38
