3228
DER-837 - 45 W USB PD 3.0 power supply with InnoSwitch3-PD PowiGaN with 3.3 V – 11 V / 5 A (45 W power limit) PPS output (INN3879C-H803)
DER-837 - 45 W USB PD 3.0 Power Supply with 3.3 V – 11 V / 5 A (45 W Power-limited) PPS Output Using InnoSwitch3-PD PowiGaN (INN3879C-H803)
45 W USB PD 3.0 power supply with InnoSwitch3-PD PowiGaN with 3.3 V – 11 V / 5 A (45 W power limit) PPS output (INN3879C-H803) Using InnoSwitch3-PD – Offline QR flyback switch IC with integrated USB Type-C and USB PD controller, integrated high-voltage switch, synchronous rectification and FluxLink feedback Integrated USB Type-C and USB PD controller reduces footprint and eliminates the need for external microcontrollers Input - 90 VAC – 265 VAC variable output - 5 V / 5 A, 9 V / 5 A, 15 V / 3 A, 20 V / 2.25 A, 3.3 V – 11 V / 5 A PPS (45 W power limit), 3.3 V – 16 V / 3 A PPS or 3.3 V – 21 V / 2.25 A PPS Output 45 W USB PD 3.0 Power Supply with 3.3 V – 11 V / 5 A (45 W Power-limited) PPS Output Using InnoSwitch3-PD PowiGaN (INN3879C-H803)Uses InnoSwitch3-PD – off-line QR Flyback Switcher IC with Integrated USB Type-C and USB PD Controller, Integrated High-Voltage Switch, Synchronous Rectification and FluxLink feedbackIntegrated USB Type-C and USB PD Controller reduces footprint, no external microcontroller requiredInput - 90 VAC – 265 VACVariable output - 5 V / 5 A, 9 V / 5 A, 15 V / 3 A, 20 V / 2.25 A, 3.3 V – 11 V / 5 A PPS (45 W Power-limited), 3.3 V – 16 V / 3 A PPS, or 3.3 V – 21 V / 2.25 A PPS Outputs
Blockdiagram
Search Datasheet?
Forum More
Update:2025-06-28 10:24:31
