aytwartoofyoroo
DER-580 - 118 W High Line Input Non-PFC CV/CC Flyback Charger Power Supply
DER-580 - 118 W High Line Input Non-PFC CV/CC Flyback Charger Supply
This engineering report describes a 59 V (nominal), 118 W flyback reference design for operation from 180 VAC to 264 VAC supplies. The power output is designed with constant voltage/constant current characteristics for battery charger applications. The charging circuit is optimized for lead-acid batteries. When the current drops below ~0.5 A during charging, the output voltage switches the 59 V charge voltage to the 56 V float voltage to keep the battery charged without overcharging. This is a standard feature of lead acid battery chargers. The design is based on the TOP267EG without PFC input stage. It is designed to operate without a fan and features a thermal switch that reduces the current limit at high temperatures (thermal foldback), allowing continuous charging at reduced output current without the need for thermal shutdown.
Blockdiagram
Design Files
Search Datasheet?
Forum More
Update:2025-08-08 05:54:38
