supremeOne
DER-406 - 5.76 W high PF non-isolated buck-boost TRIAC dimmable LED driver for A19 lamps
DER-406 - 5.76 W High PF Non-Isolated Buck-Boost, TRIAC Dimmable LED Driver for A19 Lamps
This document describes a non-isolated, high power factor (PF), TRIAC dimmable LED driver designed to drive 48 V, 120 mA over an input voltage range of 185 VAC to 265 VAC (50 Hz typical). Nominal LED string voltage. The LED driver uses LYT4322E in the LYTSwitch-4 series IC. The topology used is a single-stage, non-isolated buck-boost, which provides high power factor, constant current regulation, and provides excellent dimming performance. This document contains LED driver specifications, schematics, PCB details, bill of materials, transformer documentation and typical performance characteristics.
Design Files
Search Datasheet?
Forum More
Update:2025-08-07 02:44:31
