60W Brushless DC (BLDC) Automotive Motor Driver Design BOM, PCB Files and Gerber Files
The reference design is a BLDC motor controller designed to be powered by a single 12V (nominal voltage) supply with a wide voltage range found in typical automotive applications. The board is designed to drive motors in the 60W range, which requires a current of 5 amps. The size and layout of the board facilitates evaluation of the drive electronics and firmware, with easy access to key signals on various test points. A wide variety of motors can be connected by using a 3-contact connector or soldering the motor phase wires to the plated through holes in the board. The 12VDC supply is fused to prevent damage to the board or bench power supply in the event of a motor failure during testing. Commands and the status of the motor can be transmitted through a standard JTAG connector or through PWM input and output signals. The user can also reprogram the microcontroller through the JTAG connector, allowing customization for various applications. This design forms the solution by incorporating the DRV8301-HC-C2-KIT board.
Search Datasheet?
Forum More
Update:2025-08-04 19:35:02
  • MSP430F149
  • How to uninstall the compact framework assembly
  • 430 MCU Flash Operation (with source code and debugging process)
  • A brief introduction to MHL
  • Source code of "Microcontroller Typical Module Design Example Navigation"
  • C language implementation of string library functions (debugged with VC++6.0)
