w35RiHq
SSC338Q-IMX415-OpenIPC
SSC338Q IMX415 OpenIPC Solution Verification Board:
Open Source Digital Video Transmission OpenIPC Hardware Solution
PDF_SSC338Q-IMX415-OpenIPC.zip
Altium_SSC338Q-IMX415-OpenIPC.zip
PADS_SSC338Q-IMX415-OpenIPC.zip
BOM_SSC338Q-IMX415-OpenIPC.xlsx
92178
USBToUART
51 microcontroller download board
It can be equipped with CH340C/CH340G/CH340T, and features an onboard 3.3V regulator, with options for ASM1117 and XC6206. The 5V and 3.3V outputs have latching switches, and there are ample reserved GND pins.
PDF_USBToUART.zip
Altium_USBToUART.zip
PADS_USBToUART.zip
BOM_USBToUART.xlsx
92179
CH571F Development Board
CH571F Minimal System Version
The CH571F/CH573F development board features an onboard Type-C port, PCB antenna, and all I/O pins with 50mil spacing, allowing it to be soldered onto a functional board as a module.
PDF_CH571F development board.zip
Altium_CH571F development board.zip
PADS_CH571F development board.zip
BOM_CH571F Development Board.xlsx
92180
English vocabulary learning tool
Create a handy tool for learning English words using ESP32 and HLK-V20.
Project Name:
English Vocabulary Learning Tool
Project Requirements:
This tool is primarily for English reading and listening. Therefore, it utilizes an ESP32 and HLK_V20 to create a simple tool (a little toy) for reading and listening to words.
The main design includes four functions: sequential learning, random learning, sequential recognition, and random recognition.
MQTT allows setting the learning mode, maximum random number value, and recording learning duration and the number of words learned during testing.
Overall Design Scheme Block Diagram
Schematic Diagram Design Description
Software
Description: The software is nothing special; it mainly uses the Arduino IDE for development and related libraries.
Physical Demonstration Description
: For the main hardware, the serial port output of the voice module should ideally include a header and footer to prevent misinterpretation and inconsistent output.
Voice recognition broadcast.mp4
Identify 1.mp4
Recognize.mp4
PDF_English Vocabulary Learning Tool.zip
Altium_English Vocabulary Learning Tool.zip
PADS_English Vocabulary Learning Tool.zip
BOM_English Vocabulary Learning Tool.xlsx
92181
GL3224 Card Reader - Dual Card Dual Reading
This chip, based on the QFN-48 packaged GL3224, supports dual-SIM dual-read functionality.
Only this packaged GL3224 chip supports this; the 32-pin package only supports single-SIM single-read!
There are three versions: one with an A-port, one with an A-female connector, and the last one with a C-port male connector.
PCB design instructions:
Use the 3313 structure; the lamination order is in my files (I don't know why it's not showing up here at LCSC).
Impedance control is 20% (free; you can pay for 10%), otherwise you can't create a USB 3.0 speed board. PCB
thickness is 1.2mm.
Schematic diagram:
Appearance inspiration: USB 3.0 card reader, based on the GL3224 solution, with SD and TF card slots - LCSC open-source hardware platform (oshwhub.com).
Dual card insertion is as follows:
When ejecting, you can select only one card for speed
testing:
TF card, Kioxia G2 128G version
GL3224 chip, the official 1532 firmware supports USB 3.0, no firmware upgrade required!!! (Only specific versions of Windows 10 require an upgrade).
The reason an upgrade is needed to "support" USB 3.0 is mentioned in the official UGREEN announcement.
The chip was bought for 4 RMB from Baoxiang Electronics on Taobao, and everything works perfectly. Remember to buy two extra to avoid overheating and damaging them during soldering.
My soldering process: When
soldering chips with a hot air gun, first apply solder to the chip's pins using a bent-tip soldering iron. Do not apply
solder to the large grounding pad in the middle of the chip. Heat the chip to 350 degrees Celsius for ten seconds, then apply solder paste along the pad's lead using a syringe. Apply a little solder to the large grounding pad in the middle as well.
Place the chip on top and heat it again. After the solder paste melts, press the chip down with tweezers to prevent poor soldering of any pins.
Then remove the hot air gun and wait for the solder to cool and solidify. Then use the soldering iron to run it along all four edges of the chip (you can place it on the soldering machine first for easier touch-ups) to ensure there is no solder joint. Do
the same for other components: preheat the hot air gun, apply solder paste, then place the capacitors and resistors and heat them again (do not place LEDs at this time; place them last to avoid damaging them).
Usage:
It takes five or six seconds for the computer to recognize the chip. If you are using a camera memory card for long-term copying of materials, please purchase a heatsink on Taobao.
PDF_GL3224 Card Reader - Dual Card Dual Reader.zip
Altium GL3224 Card Reader - Dual SIM Dual Reader.zip
PADS_GL3224 Card Reader - Dual SIM Dual Reader.zip
BOM_GL3224 Card Reader - Dual SIM Dual Reader.xlsx
92182
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-26 13:16:52
