super_star
MAXREFDES165# Quad Channel IO-Link Master
MAXREFDES165# Four-Channel IO-Link Master
The MAXREFDES165# is a fully IO-Link®-compliant, 4-port IO-Link master reference design. This design uses the TMG TE IO-Link master stack and is both an IO-Link master reference design and a development and test system for IO-Link sensors/actuators. Four IO-Link ports allow for simultaneous testing of up to four different sensors (or actuators). The reference design has four robust female M12 connectors--the most common connector used for IO-Link--and ships with an IO-Link cable for connecting quickly to IO-Link compatible sensors and actuators. An AC-to-DC (24VDC/1A) power supply is capable of providing at least 250mA to each port simultaneously, and more when fewer ports are used. A USB 2.0 Type B connector allows for quick connectivity to a Windows® PC.
  • Fully IO-Link Version 1.1 compliant
  • TMG TE IO-Link master stack
  • Easy-to-Use IO-Link Device Tool V5 from TMG
  • 4 IO-Link master ports
  • Ships with all required cables
  • Field-update programmable
Competitive Advantages
  • Simultaneous four-port operation
  • Easy-to-use GUI
  • IODD import
  • Control and automation
  • IO-Link sensors
  • IO-Link actuators
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 16:08:45
