CgOfUqodT
Fan controller
The GP9101-F20K-L2H1-SW is used as the ADC chip to output PWM control for a four-wire computer fan. A diode is added to prevent excessive current from being generated when the fan is turned off. A bracket is designed to work with a variant of the Noctua fan's open-source fan shroud, suitable for office desktop fans. The PWM signal pins have select pads; pin 1 connected to pin P reduces airflow when the potentiometer is rotated in the off direction, while pin 2 connected to pin P does the opposite. Bracket adapter
download address: https://makerworld.com.cn/zh/models/195395#profileId-122615
Fan shroud download address: https://www.printables.com/model/896133-nv-aa1-12-airflow-amplifier-trunnion-mount The fan shroud must be the version with a fixed lug distance of 135!
Fan cover: https://makerworld.com.cn/zh/models/171909#profileId-123350
The ph2.0 socket is not needed.
PDF_Fan Controller.zip
Altium_fan_controller.zip
PADS_FanController.zip
BOM_Fan Controller.xlsx
93980
18650 battery module based on TP5400 capable of simultaneous charging and discharging with 5V output.
Based on the TP5400, this 18650 battery module features simultaneous charging and discharging with 5V output and IP3005A over-discharge protection.
The TP5400-based 18650 battery module features
IP3005A over-discharge protection, shutting off when the voltage is below 3V
and outputting 5V when the battery voltage is above 3V.
It has already been used in the AbenFan Pro project.
PDF_TP5400-based 18650 battery module with simultaneous charging and discharging 5V output.zip
Altium_TP5400-based 18650 battery module with simultaneous charging and discharging 5V output.zip
PADS 18650 Battery Module Based on TP5400 with Simultaneous Charging and Discharging 5V Output.zip
BOM_TP5400-based 18650 battery module with simultaneous charging and discharging 5V output.xlsx
93981
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-24 10:36:33
