This is a small idea I had before graduation. I saw someone else make one on Bilibili and wanted to replicate it. It's quite meaningful for my major and has a strong professional focus. I've designed several different versions so far. The front features a map of the Nanquan campus, and I put a lot of effort into replicating the map and school emblem one-to-one. The back has three different patterns, which reflect Electronic Information Engineering, my major. I've also designed a 4-layer NFC version. The current prototype has exposed copper on both sides, and adding NFC coils would make the back look bad. A 2-layer NFC version would require sacrificing one side of the exposed copper, so that's not designed yet. Also, the 4-layer board has vias, and to make it look nice, I'd have to use blind via technology, which would be too expensive.
Anyway, I couldn't find any existing projects from Chongqing University of Engineering on any major platforms. Now I've laid the groundwork, which is drawing the school emblem and campus map. Interested juniors can search for "Chongqing University of Engineering" on the JLCIC Open Source Plaza to find the project. Students with ideas can download it and optimize it according to their own ideas.
Additionally, please note that this design is not for commercial use. This is to respect the spirit of open source and because the fonts used in this design are not authorized by the author and cannot be used commercially.
PDF_【Chongqing University of Engineering】PCB Campus Card & Campus Map & Graduation Souvenirs.zip
Altium_【Chongqing University of Engineering】PCB Campus Card & Campus Map & Graduation Souvenirs.zip
PADS_【Chongqing University of Engineering】PCB Campus Card & Campus Map & Graduation Souvenirs.zip
Small and portable, it can be carried with you to easily check the current UV intensity.
In the sweltering summer heat, how can you not constantly monitor the UV levels outdoors? Otherwise, a happy boy might unknowingly turn into a happy, tanned boy!
Therefore, you need a device that can check the current UV intensity at any time, providing a one-click view of both sunlight and UV levels so you can take timely preventative measures.
This solution uses Huada's HC32L110 main controller, a 0.91-inch OLED screen, and a GUVA-S12SD UV sensor.
The product features a low-power design and automatically enters sleep mode when not in use.
The new version of AP-AMS is compatible with multiple solutions and adds I/O pull-down resistors.
GitHub project: https://github.com/applenana
This PCB is the control board for the AP-AMS project. Key features:
1. The board uses an LM2596S to accept 35V-5V step-down to 5V, and an AMS1117 to step down 5V to 3.3V.
2. Three WS2812 (5050) circuits are connected in series to display the operating status.
3. A TC118S is used to control a single motor.
4. An ESP12F module is used as the main controller.
5. Three I/O channels are open: I/O 14 is pulled low via a 51k resistor, I/O 16 is pulled low via an internal pull-down resistor in the ESP12F, and the ADC can be optionally pulled low via a 51k resistor.
Note: Most components on the board have short-circuit protection, but the motor driver IC [TC118S] does not. Under normal use, this IC is stable and durable, but it will fail if short-circuited. Please ensure proper insulation of the motor!
BD0C70F21843AE6AD8123FEF8398C0CE.mp4
PDF_AP-AMS Control Board 3.0.zip
Altium_AP-AMS Control Board 3.0.zip
PADS_AP-AMS Control Board 3.0.zip
BOM_AP-AMS Control Board 3.0.xlsx
94138
Developing an ammeter based on a 51 microcontroller
This USB power meter, based on the STC8H1K17 main controller and sampling the INA180, can detect the main circuit voltage and current, D+ and D- voltages, display running time, real-time power, and power consumption statistics. It includes a button to clear running time and power consumption statistics. It also features a PD decoy function.
Summer is here, and electricity consumption is increasing as various appliances are used more frequently. This led to the creation of a power meter to calculate electricity usage. This project references https://oshwhub.com/l1009184289/usb-dian-y. The main
control
chip is an STC microcontroller, and the current sampling chip is a Texas Instruments INA180. This chip can detect the main circuit voltage and current, D+ and D- voltages, display running time, real-time power, and current flow statistics. It also includes a button to clear running time and power statistics, and a CH224K decoy chip that supports both type and type input. The circuit features a Type-C input and a button for configuring the CH224K spoofing voltage. The screen uses a 0.96-inch ST7735TFT (the spoofing program function is not yet written;
the schematic design description includes:
the first part is the power supply section and INA188 sampling circuit design;
the second part is the Type-C input and CH224K spoofing circuit design;
then the DC-DC circuit uses an ME3116 step-down chip
connected in series with a 10k resistor for voltage division and sampling;
finally, the main control and screen circuit
PCB design description includes
a two-layer board with color silkscreen printing
; software description;
physical demonstration description;
and precautions.
Reproduction is not recommended at this time.
A demonstration video is also available.)
WeChat_20240621125534.mp4
WeChat_20240621125530.mp4
WeChat_20240621125523.mp4
USB Power Meter Based on STC Microcontroller.zip
PDF_Ammeter Developed Based on 51 Microcontroller.zip
Altium_Ammeter Development Based on 51 Microcontroller.zip
PADS_Ammeter Development Based on 51 Microcontroller.zip
BOM_Development of an Ammeter Based on a 51 Microcontroller.xlsx
94139
electronic
