n0VMCRvO
ESC (not verified)
This PCB is for testing purposes only, exploring the feasibility of 3D printing a fan (fan printout address: fan). The PCB design was inspired by a Bilibili video ([FPV Drone] DIY BLHeli_S ESC, Homemade Drone ESC, Recording the Process from Schematic to Firmware Download). The board has been successfully manufactured and soldered. However, it has yet to pass the firmware test. Therefore, this project is currently only for demonstration and exchange. An improved version is expected to be released around summer vacation. At that time, the ESC will be smaller and more perfect. Below are pictures of the actual product.
PDF_Electronic Speed ​​Controller (Unverified).zip
Altium_eScreenEsc (Unverified).zip
PADS_Electronic Speed ​​Controller (Unverified).zip
94846
ESC and PWM output controller
This project was also intended as a module for fans, but it was eventually cancelled due to time constraints. Like the previous ESC, this module failed verification due to repeated rewriting. It was based on the work of this open-source author (a brushless ESC PWM signal generator), with some size reductions and the addition of an indicator light. Below are some physical demonstration images.
This component is only for demonstration and discussion; future improvements may be made, or it might be integrated with an ESC.
PDF_Electronic Control Screw (ESC), PWM Output Controller.zip
Altium_Electronic Speed ​​Controller (ESC) and PWM Output Controller.zip
PADS_Electronic Speed ​​Controller (ESC) and PWM Output Controller.zip
94847
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-29 04:57:01
