It can be a flashlight—it lights up when there's light. No light? Absolutely nothing!
When it's hot, it can be a small fan, perfect for drying your hair.
When you're bored, you can read a novel.
In case of danger, it can be used as a safety shield.
The flashlight function is controlled by a photoresistor that detects light intensity. It
uses an IP5305 rechargeable lithium battery, allowing you to use it outdoors.
The fan uses an RZ7888 motor control chip.
Novels and documents are downloaded using an ESP8266EX/ESP12F and saved to the W25Q flash memory.
With a large 1.8-inch screen, you won't have trouble seeing the text clearly.
VID_20240418_171906.mp4_20240419_101948.mp4_20240420_124441.mp4
VID_20240418_171933.mp4_20240419_102052.mp4_20240420_124526.mp4
PDF_Da Vinci's Secret Weapon.zip
Altium_Da Vinci's Secret Weapon.zip
PADS_Da Vinci's Secret Weapon.zip
BOM_Da Vinci's Secret Weapon.xlsx
95137
Guangdong Baiyun College Business Card
Connecting the LEDs and button pads on the upper and lower boards with wires
allows soldering of a 3.7V battery.
The TYPE-C rechargeable
LED power indicator
section can be referenced from the author sam_god's open-source project. [Map of Guangdong Baiyun University (West Campus) - JLCPCB EDA Open Source Hardware Platform (oshwhub.com)].
If there is any copyright infringement, please contact us for removal.
0.hex
BOM_af3f0377304546c0b5a75c6452de7cc3_20231206170404.xls
PDF_Guangdong Baiyun University Business Card.zip
Altium_Guangdong Baiyun College Business Card.zip
PADS_Guangdong Baiyun College Business Card.zip
BOM_Guangdong Baiyun University Business Card.xlsx
95139
YBA-AMS_Remix
3D Printing Single-Channel Material Holder Control Board
Modified from YBA-AMS
⚠ Please note that although the current version can be supplied with the AMS lite connector, its power consumption is quite high. Please consider this carefully. The next version of the PCB will be compatible with MP1584 to solve the LDO power consumption issue. You can wait for this to be resolved before manufacturing.
Recommended process
Board thickness: 1.6mm
Minimum hole diameter/outer diameter: 0.3mm (free) (outer diameter 0.4/0.45)
Add markings to the board: Add serial number QR code
QR code size: 8*8mm
QR code location: Designated location
Modified content:
Changed 4 channels to 1 channel for convenient individual control in the consumable drying box.
Changed USBC/DC power supply to AMS lite interface power supply.
DRV8833 was modified from a finished board for soldering, optimizing the PCB area.
The manual control switch has been changed from wiring to soldering, directly fixing it to the consumable drying box.
You can see both the switch board and motor board in this project; this is designed to optimize wiring within the drying box. It requires the next version of the spool holder. You can check the update status of [YBA-AMS(Remix)] on MakerWorld.
Modified note:
From 4 channels to 1 channel, to control the sole holder in one case.
From USB-C/DC power supply to AMS lite.
From finished DRV8833 board to soldered DRV8833.
From cable-connected switch to soldered switch on board.
You can find the switch board and motor board in this project; it's designed for the cable management in case. They should be used with the next version of the spool holder; you can kindly check the update status of [YBA-AMS(Remix)] on MakerWorld.
BOM_PCB[YBA-AMS(Remix)].xlsx
PDF_YBA-AMS_Remix.zip
Altium_YBA-AMS_Remix.zip
PADS_YBA-AMS_Remix.zip
BOM_YBA-AMS_Remix.xlsx
95140
AT8236 Motor Driver Board & Power Board
This driver module uses the AT8239 motor driver and a TPS5450DDA to provide a 5V 5A power output.
This project serves as the power driver module for a ROS car. All interfaces are connected to the control core board using simple horn-shaped connectors and FC cables, simplifying the board and reducing costs. Any board issues are addressed by simply replacing the faulty one. The board
also uses two TPS5450DDA converters for 5V/5A output to power the host computer, Raspberry Pi, or other modules like Luban Cat. Theoretically, the maximum output is 5A, but this hasn't been tested due to the lack of a load tester. However, both output voltages are quite good. Solid-state capacitors are used throughout the board. An INA219 was added for circuit detection, which provides more data compared to an ADC, such as current, voltage, and power.
The 3.3V connection was initially forgotten, so a jumper wire was used; this has now been fixed in the project, and you can confidently build a board if needed.
The TPS5450DDA circuit can also be extracted from the schematic and used. It has been tested and works without issue. It also provides a 3.3V output from the ASM1117 without any problems.
The board also has an onboard buzzer and two controllable 5V outputs, which can be controlled via GPIO for future expansion. I plan to add a USB hub later, using this 5V interface to power peripherals, since the ROS car will also have a depth camera and LiDAR.
The most important part of the motor driver board is the motor drive. One path has been tested and works without any issues. I'm unsure how to upload the video, so please feel free to discuss it. I'm not a professional, and the board certainly has many problems, so please bear with me.
087953d0fc2162f3f086e0ffda9efc82.mp4
369ebe43be84a53d48402c6f511059b2.mp4
PDF_AT8236 Motor Driver Board & Power Board.zip
Altium_AT8236 Motor Driver Board & Power Board.zip
PADS_AT8236 Motor Driver Board & Power Board.zip
BOM_AT8236 Motor Driver Board & Power Board.xlsx
95141
Liangshan School Electronic Keyboard Expansion Board
Design of Electronic Keyboard Expansion Board Based on LCSC Liangshanpai:
1. Objective: To become familiar with the development process of embedded projects and master the ability to design a game console hardware circuit, software programming, and system debugging.
2. Function Introduction:
Implements I2C display of current information; (to be implemented later, already driven. Unsure of its use yet)
Implements 23-button control;
includes sound output functionality;
3. Skills Acquired:
Hardware Development Ability
: Learns embedded project circuit analysis skills and how to understand schematic diagrams;
gains basic skills in component selection and datasheet reading;
learns schematic and PCB design skills, cultivating independent project design thinking;
understands the design of I2C screens, PWM audio circuits, etc.;
masters the use of instruments such as multimeters, oscilloscopes, signal generators, and student power supplies, possessing basic circuit analysis skills;
masters the use of tools such as soldering irons and hot air guns, possessing component soldering and hardware debugging skills, becoming a new generation of "soldering masters";
Software Development Ability:
Understands the basic functions and peripherals of GD32, and gets started with GD32 project development;
understands audio encoding formats and implements audio output;
understands the I2C protocol and OLED driver principles, and implements screen driving;
masters interface creation;
understands the basic working principles of audio;
masters embedded software development, code reading, and bug debugging methods and techniques;
GD32F450.hex
Electronic Keyboard.rar
501da5fe7d2ef95f369b09376aec2983.mp4
PDF_Liangshan School Electronic Keyboard Expansion Board.zip
Altium_Liangshanpai Electronic Keyboard Expansion Board.zip
PADS_Liangshanpai Electronic Keyboard Expansion Board.zip
BOM_Liangshanpai Electronic Keyboard Expansion Board.xlsx
95143
electronic
