wT6ez
Esp32C3 Learning Board
This is a learning/expansion board based on the HeZoo Esp32C3.
Connectable modules include: a 0.96-inch OLED screen, a 1.8-inch TFT-LCD, a MAX4466 sound sensor, an HC-SR04 ultrasonic module, and an MPU6050 gyroscope.
menu.ino
PDF_C3 Learning Board.zip
Altium_C3 Learning Board.zip
PADS_C3 Learning Board.zip
BOM_C3 Learning Board.xlsx
96050
Four-layer board STM32F103C8T6
STM32F103C8T6
The four-layer board has been tested and is working properly.
cc997760ab4775ff0daf992a5aa9eb7e.mp4
PDF_Four-layer board Stm32f103c8t6.zip
Altium 4-layer board Stm32f103c8t6.zip
PADS_4-layer board Stm32f103c8t6.zip
BOM_Four-layer board Stm32f103c8t6.xlsx
96054
5V12A step-down module
Built using the Chipone XL4016... seems pretty good, cheap and easy to use.
There are several unused 12V server power supplies. There aren't many things that require 12V power, but many require 5V, so I made this
module. The heat generation after half an hour of 5A output
and the ripple at 5A output were observed
. At full power (12A) with a fan, it's manageable, but the ripple increases.
The ripple at 12A output
seems acceptable in the tests. The load test results on the host computer are also very stable.
However, it's worth noting that if this module fails, it will directly output the input voltage. USB devices are quite voltage-sensitive, so some protection circuitry should be added.
PDF_5V12A Step-Down Module.zip
Altium_5V12A step-down module.zip
PADS_5V12A step-down module.zip
BOM_5V12A Step-Down Module.xlsx
96056
Multifunctional bottled water heater
It can be used to heat bottled water, as a night light, as a heater, and as a pen holder; it's very practical.
Used for heating bottled water, this device can also be used as a nightlight, a heater, and a pen holder—very practical.
The design theme is rocket-themed, and it looks quite attractive from top to bottom. The bottom features four LEDs for illumination and colorful PCB silkscreen printing, making it quite aesthetically pleasing.
The entire shell is 3D printed, reinforced by four supports, maintaining a certain thickness and using substantial materials.
The heating element uses a carbon fiber heating module, which is very practical and available for around 3 RMB on Taobao. Because the heating is very slow, there's no need to worry about overheating.
See the attachment for the 3D design results.
The electronic circuitry consists of three main parts:
a power interface circuit (powered via a Type-C interface, supplying power to the logic and lighting circuits)
, a control logic circuit (using a C51 microcontroller to control the LEDs and heating plate), and a
lighting circuit (using colorful silkscreen printing and four LEDs for internal lighting).
All these parts need to be fixed inside the heating tank.
The control logic circuit has an opening on the panel for operation.
The heating container can hold standard-sized purified water and mineral water, heating it to around 40 degrees Celsius, which is perfect for drinking.
Finally, it's given to the children to draw on.
Heating Barrel.STL
PDF_Multifunctional Bottled Water Heater.zip
Altium Multi-functional Bottled Water Heater.zip
PADS_Multifunctional Bottled Water Heater.zip
BOM_Multifunctional Bottled Water Heater.xlsx
96058
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-27 23:56:45
  • TD-SCDMA test encounters setback
  • 串口的WriteFile問題
  • Mini logic analyzer open sourced by foreigners, with circuit diagram, software, and firmware
  • MDK + JLINK set to debug in memory, MDK crashes!
  • Regarding the LCD Segments issue in MSP430 selection!
  • Hope for Infineon
