323 views|0 replies
1969
Posts
Resources
The OP
Energy meter [Copy link]
Energy table: 1 3 9 1 5 1 9 1 8 3 6
Energy meter product functions
1. Heat and cooling capacity measurement
It can measure the heat consumed by the central heating system, and the cooling capacity consumed by the central air conditioning cooling system at the same time, realizing the integrated heat and cooling capacity measurement. It is suitable for household heat metering of central heating, and also for household metering of winter heating and summer cooling of central air conditioning system.
2. Data remote transmission function
It has infrared, m_bus or rs485 data communication interface, which can realize remote data reading and collection. With remote control valve, it can also realize remote centralized control
3. Convenient parameter query
It can display parameters such as cumulative heat, cumulative cooling, cumulative flow, instantaneous flow, inlet and return water temperature, temperature difference, cumulative working time, and working status of the meter; the integral adopts a split structure, which can be installed as a whole or led out for split installation, which is convenient for operation.
4. Data storage
It can store 24 months of historical data, which is convenient for users to query management and statistical analysis.
Product pictures
Product advantages (features)
1. Integrated hot and cold metering, suitable for central heating and central air conditioning systems;
2. The meter body pipe section is a straight-through structure, not easy to clog, and has low pressure loss;
4. Strict transducer packaging and testing process, stable measurement performance, and reliable long-term operation;
5. The integral structure is designed with a split structure, which is convenient for user operation;
6. Flexible installation position and installation method, convenient construction;
7. IP65 and IP68 protection level design, suitable for harsh installation and operation environment;
8. Lithium battery power supply, ultra-low power consumption design, 220V or 24V.
This post is from Release of Information
Guess Your Favourite
Find a datasheet?
EEWorld Datasheet Technical Support
Related articles more>>
    Copyright © 2005-2025 EEWORLD.com.cn, Inc. All rights reserved 京B2-20211791 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号
    快速回复 返回顶部 Return list
