qoistoochee128
STC8H3K64S2 makes 12864LCD dual-channel voltage and current capacity meter
Copy the homework of the great god and share the process
https://www.mydigit.cn/thread-298246-4-1.html
https://oshwhub.com/13977300488/stc8h3k-tssop20-dian-ya-dian-liu-biao_copy_copy_copy
First post the finished product picture, the interface is complete, usb typc-c xt30
originally used the disassembled card machine screen, replaced with tb 9.9 free shipping st7567 LCD128*64, this screen has many twists and turns. It turns out that 3.3v can't light up but only the backlight. It must be greater than 4.2v to be normal. I originally wanted to power it with a lithium battery, and the ldo couldn't work properly under 5v, so I had to change to an external power supply.
https://item.taobao.com/item.htm?spm=a1z0d.6639537.1997196601.235.687274840CoKtg&id=588631508167
The screen needs to change the code, otherwise it is reversedCode modification4-19 Now I directly fly the wires and add a physical toggle switch to solve the problem of low voltage and cannot start. XL1059 adjusts the voltage to 4.2v, and 5v input is finally possible. I have tried 3 meters, 2 hardware ina266, one esp32 pico d4, and one stm32. STC8H is a pure 12-bit ADC microcontroller. The accuracy
of STC8H microcontroller is ok. It turns out that the previous STC8 The program of the 15 series is different. This screen is too big. I want to port it to 0.96tft or 0.96oled. I spent a day to light up a 0.96 oled, but the tft can't light up and flickers. I don't have the ability to do it. I won't bother anymore.
STC8H3K64S2_TSSSOP20 dual 12864 voltage and current meter - copy.rar
WeChat_20220419142555.mp4
BOM Download
PCB_PCB_STC8H3K64S2 makes 12864LCD dual-channel voltage and current capacity table copy_1.8_2022-09-23.pdf
PCB_PCB_STC8H3K64S2 makes 12864LCD dual-channel voltage and current capacity table copy_1.8_2022-09-23.json
PCB_STC8H3K64S2 makes 12864LCD dual-channel voltage and current capacity table copy_1.8_2022-09-23.pcbdoc
Gerber_PCB_STC8H3K64S2 makes 12864LCD dual-channel voltage and current capacity table copy_1.8.zip
Schematic_STC8H3K64S2 makes 12864LCD dual-channel voltage and current capacity table_2022-09-23.pdf
SCH_STC8H3K64S2 makes 12864LCD dual-channel voltage and current capacity table_2022-09-23.json
TSSOP201.4 inch LCD dual voltage and current capacity meter_2022-09-23.schdoc
61765
【CW32】CW32 brushless motor
Introduction: CW32 brushless motor driver
Understand and learn the use of CW32 and the drive of brushless DC motors. This project includes a brushless DC motor driver board and a CW32F030C8T6 driver board. Physical objects and verification have been completed.
202206232250.mp4
BOM Download
PCB_PCB_driver board_2022-09-23.pdf
PCB_PCB_driver board_2022-09-23.json
PCB_driver board_2022-09-23.pcbdoc
Gerber_PCB_driver board.zip
PCB_PCB_CW32_DRV_2022-09-23.pdf
PCB_PCB_CW32_DRV_2022-09-23.json
PCB_CW32_DRV_2022-09-23.pcbdoc
Gerber_PCB_CW32_DRV.zip
Schematic_【CW32】CW32 brushless motor_2022-09-23.pdf
SCH_【CW32】CW32 brushless motor_2022-09-23.json
【CW32】CW32 brushless motor_2022-09-23.zip
61785
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 21:40:43
