4580 views|5 replies
Posts
Resources
The OP
A novice asks for advice on active ultrasonic probes [Copy link]
I would like to ask you guys, what are the advantages and disadvantages of active ultrasonic probes compared to passive ones.
This post is from DSP and ARM Processors
Latest reply
Thanks!!!!!!!!!!!!!!!!!!!!!!!!!  Details Published on 2011-7-20 11:32
1w
Posts
132
Resources
Active ones have internal drive circuits. Generally speaking, they are more expensive than passive ones with self-built drive circuits, but their performance and consistency are usually better. Making your own drive is more flexible and you can achieve the balance you want in performance and cost.
Posts
Resources
Could you be more specific, sir?
2120
Posts
Resources
Passive is like headphones, you can use it by plugging it in, it is very convenient but the effect is not good. Active is like speakers, it needs a separate power supply, but the sound quality is just right.
1w
Posts
132
Resources
You should read the instruction manual of the active ultrasonic probe and then compare it with the passive one to understand it. In fact, what I said before is detailed enough. Whether you can understand it depends on whether you have the relevant basic knowledge.
Posts
Resources
Guess Your Favourite
Just looking around
Find a datasheet?
EEWorld Datasheet Technical Support
Related articles more>>
    Room 1530, Zhongguancun MOOC Times Building, Block B, 18 Zhongguancun Street, Haidian District, Beijing 100190, China Tel:(010)82350740 Postcode:100190
    Copyright © 2005-2025 EEWORLD.com.cn, Inc. All rights reserved 京B2-20211791 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号
    快速回复 返回顶部 Return list
