6570 views|4 replies
47
Posts
Resources
The OP
Analysis of STM32 driving MOS tube circuit [Copy link]
微,大家能帮忙前作一个上海电影吗不看懂Didn't understandDidn't understandDidn't understandDidn't understandDidn't understandDidn't understandDidn't understandDidn't understandDidn't understandDidn't understandDidn't understandDidn't understandDidn't understandDidn't understandDidn't understandDidn't understand
This post is from stm32/stm8
Latest reply
I checked the datasheet of BTS410E2, mainly to see the pin functions. When IN is high, it is turned on. When one end of the optocoupler, GPIO E8, is low, the right end is turned on. Because it is connected to R55, it can be maintained at a high level, and then the MOS tube is turned on and starts working. VBB is the power supply. The resistor and diode should be when IN is 0, the MOS tube is turned off, and a current will flow from VBB to the power supply. Connecting a resistor and a diode can protect the circuit (this is some of my own speculation, I think there is some basis). ST is diagnostic feedback, low level is a fault (low on failure). It should be possible to see that the optocoupler below is mirror-symmetrical with the one above. When ST is low, it is turned on, and the GPIO E9 input detects a low level (indicating a fault). R53 and R57 should be the chip's requirements for input current. OUT is connected to the load (load)  Details Published on 2018-7-2 20:59
3w
Posts
Resources
Can you help me analyze this circuit? Where is the circuit?
47
Posts
Resources
I'm not familiar with posting on the forum, this is the circuit diagram
电路图
电路图
Posts
Resources
Comments
Thank you so much.  Details Published on 2018-7-3 08:37
47
Posts
Resources
xuezehui posted on 2018-7-2 20:59 I checked the datasheet of BTS410E2, mainly to see the pin functions. It is turned on when IN is high, and GPIO E8 at one end of the optocoupler is low...
Thank you very much.
Guess Your Favourite
Just looking around
Find a datasheet?
EEWorld Datasheet Technical Support
Related articles more>>
    Copyright © 2005-2025 EEWORLD.com.cn, Inc. All rights reserved 京B2-20211791 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号
    快速回复 返回顶部 Return list
