Home >
Control Circuits >Infrared Thermal Release Remote Control Circuits > Infrared automatic hand dryer circuit and maintenance
Source: InternetPublisher:newrudeman Keywords: Infrared control Updated: 2024/06/13
Infrared automatic hand dryers are widely used in public places such as hotels, hospitals, and restaurants. In order to facilitate maintenance, the circuit of the machine is analyzed and the circuit diagram is drawn (see attached figure). Common fault causes and simple treatments are introduced for reference.
1. Circuit Principle
In the circuit, V1, V2, R1, and C3 form a 40kHz oscillator, whose output drives the infrared tube D6 to emit 40kHz infrared light. When a person's hand reaches under the hand dryer, the infrared light reflected by the hand is received by the phototube D5. It is converted into a half-wave pulsating DC signal. The signal is coupled to the positive input of the first-stage op amp through C4 for amplification, and a small bias voltage is added to the negative end to prevent small signal interference. The amplified signal output from pin ① is shaped and smoothed by R7, D7, and C5 to become a DC signal. It is sent to the positive input of pin ⑤ of the second-stage op amp for comparison and amplification. The flip threshold of the second-stage op amp is determined by the voltage divider of R9 and R11 connected to the negative input of pin ⑥. R10 is the positive feedback resistor of the op amp, and together with C5 and C6, it forms a delay circuit to prevent power failure caused by interference when the hand being detected moves. When pin ⑦ of the op amp outputs a high level, V3 is turned on, and the control relay turns on the power of the heater and the hair dryer.
2. Common fault causes and troubleshooting
Fault 1: The indicator light is on after power is turned on, but no hot air blows out when you reach out your hand.
Analysis shows that the possibility of the fan and heater failing at the same time is very small. Most likely, the relay is broken or not working. The non-action of J may be due to V3 not conducting; the op amp has no output; D6 and D5 fail; V1 and V2 do not oscillate or 7812 is damaged, resulting in no 12V voltage.
When checking, first check whether there is 12V voltage. If there is, reach out and test whether the level of pin 7 of the op amp changes. If there is a change, check V3 and the relay backward; if there is no change, check the op amp circuit, photoelectric conversion and oscillation circuit forward.
Fault 2: The indicator light is on after power is turned on, but the induction sensitivity is low.
Latest Control Circuits Circuits
- What is a self-locking circuit?
- How to use a microcontroller to control a servo motor?
- How to choose the right level of integration to meet motor design requirements?
- DIY an electromagnetic levitation device
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Design and analysis of the principle of automatic power-off switch during power outage
- Design and analysis of a four-bit remote control component capable of remote reset
- Do-it-yourself trial production of phase failure protection device
- Infrared detection alarm
- Car audio system anti-theft circuit
Popular Circuits
- Pyroelectric automatic door control circuit
- Electromagnet control circuit
- Infrared voice control circuit
- Assembly line outage monitoring circuit
- High-rise residential walkway lighting control circuit
- Automatic tuning control circuit
- Temperature detection control circuit of electric hot water bottle
- Control circuit of Gao Shida 25860T microwave oven turntable assembly
- DC motor forward and reverse control circuit
- Power supply circuit with multiple outputs (MAX1902)
