What is a self-locking circuit?
Source: InternetPublisher:奥特man123 Keywords: Self-locking circuit Updated: 2025/02/25
What does self-locking circuit mean? Self-locking circuit diagram
Literally, it is a circuit that locks itself. See the picture:
In the figure above, buttons 1 and KA are normally open and connected in parallel, and button 2 is normally closed and connected in series in the circuit. When button 1 is pressed, the power is turned on, the KA coil is energized, and the contacts are closed. At this time, even if button 1 is released, the current will still flow through the closed KA contacts, and the KA coil will not lose power, unless button 2 is pressed to cut off the entire circuit. This kind of circuit that locks itself is called a self-locking circuit, which is often used for starting motors, etc.
In our air-conditioning control cabinet circuit, KT3's zero return protection function and cooling and heating fault protection are all self-locking.
- Car ice warning circuit sharing
- Tutorial on making your own remote-controlled robotic arm
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- What are the challenges in designing a permanent magnet linear generator?
- Perform surgery on the speaker protection circuit
- Electric vehicle battery charging protection circuit
- Infrared blocking alarm device
- Motorcycle anti-theft device circuit design
- Water supply reminder after water outage
- Homemade disinfectant circuit
- Multi-pole leakage protector circuit a
- Relay control circuit a
- Detection and control circuit of electromagnetic stove
- Humidity detection box control circuit in greenhouse
- Steam iron temperature detection control circuit
- Temperature detection control circuit for vegetable greenhouses
- Power supply circuit with multiple outputs (MAX1902)
- 35W half-wave resistor-capacitor phase-shift trigger actuation control circuit
- Apply LOGO! Electric gate control circuit b
