FM tracking transmitter based on 4 transistors
Source: InternetPublisher:supremeOne Keywords: emitter transistor Updated: 2024/01/05
The picture below is an FM tracking transmitter based on 4 transistors. This trace transmitter diagram has no additional comments, try to discover this circuit yourself.
Component list:
R1 = 100K Ohms
R2 = 10 Ohms
R3 = 47K Ohms
R4 = 220 Ohms
C1 = 4.7uF/16V
C2, C5 = 1nF
C3 = 10 – 40 pF trimmer capacitor
C4 = 4.7pF
Q1 = 2N3906 PNP transistor
Q2, Q3, Q4 = 2N3904 NPN transistor
L1 = 4-5 turns 22 ga. Magnet wire is tightly wound around a 1/8" non-conductive core
Antenna = 10 to 12” cable
This FM tracking transmitter is powered by a wide voltage (3-9v) and can be powered by 3V or 9V batteries.
- Methods to reduce mutual coupling between antenna elements
- What is the basic principle of parametric amplifier?
- Using 3DA87C to make FM transmitter circuit
- Making an FM receiver with a high-frequency head
- MAX23691/Q 2000-800 MHz Dual-Band Tri-Mode Transmitter
- MAX2366/MAX2367/MAX2368 I/Q 2000-1700 MHz/1000-800 MHz dual-band
- Radio coding transmission circuit composed of MICRF102 and PT2262
- RXM-433/418/315-LC-S Series Receiver Modules
- RXM-433/418/315-LC-P AM Receiver Module
- F05A/B/C Series AM 433/315 MHz RF Transmitter Module
- Simple transistor inverter circuit diagram
- 90MHz transistor resonant power amplifier circuit
- Gas flameout alarm circuit
- Transistor controlled rectifier circuit d
- JSJ type transistor time relay circuit
- Transistor meter circuit c
- Infrared remote control light switch circuit (1)
- transmitter toy circuit
- FM transmitter circuit 05
- CATV open circuit transmitter
