The power-on delay output low level circuit composed of NE555
Source: InternetPublisher:赔钱虎 Keywords: NE555 delay circuit Updated: 2024/10/17
The power-on delay output low level circuit is shown in the figure below. When the circuit is connected to the power supply, since the capacitor C has no time to charge, the ② and ⑥ pins of the 555 time base circuit are at a low level, and the ③ pin outputs a high level. As the capacitor C charges, the potential of the ② and ⑥ pins of the 555 time base circuit begins to rise. When the potential of the ② pin rises to 2/3 Vcc, the circuit state flips, and the ③ pin changes from a high level to a low level and remains there. The delay time tw=1.1RC. This circuit is often used to control the local circuit in the whole circuit to stop working by disconnecting the power supply after a certain period of time of power-on.
- NE555 light-controlled doorbell
- NE555 sequential timing circuit diagram
- Water level automatic control system circuit based on NE555
- 555 lantern electronic switch circuit
- 555 linear pulse width modulator circuit
- 555 infrared transmitter circuit
- 555 simple electroacupuncture anesthesia instrument circuit
- 555 voltage controlled oscillator circuit using Vc terminal to control duty cycle
- 555 simple electronic keyboard circuit (1)
- 555 calculator/stopwatch converter circuit
- Assembly line outage monitoring circuit
- Very simple voltage multiplier circuit block diagram
- Long delay circuit using integrated circuit 5
- Delay circuit two using 555 time base integrated circuit
- Light-controlled street light circuit using NE555 (1)
- Use NE555 to make a three-way lantern controller
- Water tank automatic water supply control circuit
- Clever use of NE555 as a cycle timer circuit with adjustable on-off time
- Control circuit using NE555 integrated circuit_1
- DC voltage polarity converter circuit diagram composed of NE555
