12kHz signal generator
Source: InternetPublisher:ohahaha Keywords: Signal generator Updated: 2023/11/17
The 12kHz signal generator as shown in the figure consists of a crystal oscillator and an alarm circuit. The oscillator output amplitude is stable with a variation of <±0.26dB.
Component selection:
Transistor VT1, VT3: 9014, 65≤β≤115; VT2, VT4: 3DGl308, 60≤β≤85. Thermistor RT: RRW1-2 type. Quartz crystal SJT: BE42-12kHz. The variable device T uses ferrite MXD-2000, the magnetic core is GV36X22, L1-2Φ0.17mm high-strength enameled wire, wound with 57 turns, L3-4Φ0.17mm high-strength enameled wire, wound with 37 turns. The VD3 light-emitting diodes are available in any model. The nominal power of the resistors uses 1/8W metal film resistors. Other component parameter values are as marked in the figure, and there are no special requirements.
- Basic connection circuit of HA-5340 in the same phase unity gain mode
- High-speed A/D converter with direct drive capacitive input composed of INA155/INA156
- Ultra-high frequency voltage-controlled oscillator constructed with UPC1651
- Frequency Detection and Signal Generator Made with LM567
- Precision 50Hz signal generator
- Complementary symmetric astable multivibrator circuit diagram
- Deformed capacitive negative feedback sawtooth wave circuit
- Sawtooth wave oscillator composed of integrating circuit and comparator
- CNC pulse width circuit
- Variable start/stop ramp oscillator
- Various signal generator circuits
- Home appliance repair signal generator circuit
- Staircase wave signal generator circuit
- Voltage signal generator circuit with optical isolation
- Two examples of 60Hz time base signal generator circuit circuit-a
- Sub-audio tone signal generator
- simple tv signal generator
- Sequence signal generator circuit
- 450HZ signal generator
- Various analog sound signal generators
