Ultra-high frequency voltage-controlled oscillator constructed with UPC1651
Source: InternetPublisher:吃掉星星 Keywords: Oscillator Updated: 2024/08/01
The voltage-controlled oscillator is a key circuit in the frequency synthesizer. When making amateur radio communication equipment, in order to make the local oscillator have a smaller phase noise and a smaller step frequency, an oscillation circuit with a higher oscillation frequency and a larger frequency step is generally used, and then a high-speed frequency divider is used for frequency division. However, the oscillation frequency is high and the production is difficult. The voltage-controlled oscillator made by the author using the broadband integrated amplifier μPCI651 (or μPCI676) is very simple, small in size and easy to start. It can work almost without debugging.
The circuit is shown in the figure. When the oscillation loop inductor uses a 30mm long resonant line, a frequency of 500MHz to 1000MHz can be obtained. The oscillation frequency range is greatly affected by the varactor diode, and the U-segment varactor diode in the waste E-tuning high-frequency head can be selected. The feedback capacitor and output coupling capacitor in the circuit should not be too large. If there is no suitable capacitor on hand, a double-strand enameled wire can be used instead.
- Multifunctional LC Oscillation Circuit Demonstrator
- LF353 op amp oscillation circuit
- Make a signal source with MAX038
- AD585 12bit A/D conversion system circuit
- Analog-to-digital converter application circuit design analysis
- LTC2053 thermocouple amplification circuit diagram
- Inexpensive high-precision digital clock time base circuit
- Precision gate oscillator circuit
- Oscillator circuit composed of 555 integrated circuit
- 800Hz single transistor oscillation circuit
- Power outage sound and light alarm circuit
- phase shift oscillator
- Triangular wave oscillator and output waveform using two operational amplifiers
- Self-excited intermittent oscillator practical circuit b
- Self-excited intermittent oscillator practical circuit a
- Anti-theft alarm circuit 2 with warning wires
- Adjustable frequency range 10:1 oscillator.gif
- Crystal controlled oscillator powered by the same mercury battery
