Precision 50Hz signal generator
Source: InternetPublisher:jikai233 Keywords: Signal generator Updated: 2024/07/23
This is a simple oscillator circuit that uses a crystal to generate a 50Hz frequency. It outputs a square pulse with a duty cycle of 50%. This square pulse is often used in inverters and precise clock displays. The oscillator consists of a 14-stage counter and oscillator chip CD4060, a dual J-K flip-flop CD4027, an operational amplifier LM324, and several discrete components.
The oscillator is made of a 3.2768MHz crystal and resistors and capacitors connected to the corresponding pins of IC1 (CD4046). Resistor R1 is used to limit the power and R2 is a bias resistor.
The 3.2768MHz oscillation frequency is divided 14 times and outputted at 200Hz on pin ③ of CD4060. This 200Hz frequency is then divided by 4 using the dual J-K flip-flop CD4027 to get an accurate 50Hz frequency. It is outputted from pin (15) of CD4027, while pin (14) outputs a 50Hz inverted signal. The duty cycle is 50%.
The 50Hz frequency output is buffered by the A1 and A2 operational amplifiers LM324, and two 50Hz square wave signals with opposite phases can be output from its pins ① and ⑦ respectively.
- Two common RC oscillator circuits
- 70MHz parallel crystal oscillator
- PLL FM Demodulator(4046)
- Composition diagram of transformer feedback LC oscillator circuit
- Basic connection circuit of HA-5320 in the same phase unity gain mode
- A/D converter with direct drive capacitive input composed of INA331/INA332
- AD585 12bit A/D conversion system circuit
- LTC2053 thermocouple amplification circuit diagram
- 20~20000Hz low distortion audio oscillation circuit
- 2~20MHz variable frequency transistor oscillator
- Various signal generator circuits
- Home appliance repair signal generator circuit
- Staircase wave signal generator circuit
- Voltage signal generator circuit with optical isolation
- Two examples of 60Hz time base signal generator circuit circuit-a
- Sub-audio tone signal generator
- simple tv signal generator
- Sequence signal generator circuit
- 450HZ signal generator
- Various analog sound signal generators
