Laser constant power control circuit
Source: InternetPublisher:3228 Keywords: Laser constant power control Updated: 2024/07/18
This circuit achieves the purpose of controlling the laser current through the backlight current through the connection of the op amp, so that the laser emission power is constant. The circuit is simple, and the power output can be controlled by adjusting the voltage of pin 3 of IC3. This circuit can be used in low-speed optical communication. MAX4124 is not easy to obtain, and LM358 can also be used for applications with low requirements.
- Factors affecting the life of LiFePO4 batteries, how to extend the life of LiFePO4 batteries
- Detailed explanation of the working principle of the clapper activated optical circuit
- Design of a tomato sorting machine based on Raspberry Pi
- DIY an open source air quality monitor
- How to build an autonomous robot using the DonkeyCar platform
- The production principle of high voltage self-defense flashlight and electric stick
- Automatic recovery electronic fuse with soft start function
- Electronic Rat Killer Circuit
- Laser constant power control circuit
- Test and Application of Power Amplifier TDA7294
- Laser power circuit
- Cheap Laser Diode Driver Circuit
- How does an optocoupler work? Introduction to the working principle and function of optocoupler
- 8050 transistor pin diagram and functions
- What is the circuit diagram of a TV power supply and how to repair it?
- Analyze common refrigerator control circuit diagrams and easily understand the working principle of refrigerators
- Hemisphere induction cooker circuit diagram, what you want is here
- Circuit design of mobile phone anti-theft alarm system using C8051F330 - alarm circuit diagram | alarm circuit diagram
- Humidity controller circuit design using NAND gate CD4011-humidity sensitive circuit
- Electronic sound-imitating mouse repellent circuit design - consumer electronics circuit diagram
