Electronic Rat Killer Circuit
Source: InternetPublisher:aerobotics Keywords: Electronic Rat Killer Updated: 2024/10/09
The electronic rodent killer introduced in this article uses an infrared light reflection control circuit. When a mouse enters its effective detection range, it can automatically connect the working power of the high-voltage circuit, generate high voltage and kill the mouse. Circuit working principle The electronic rodent killer circuit consists of a power supply circuit, an infrared control circuit and a high-voltage circuit, as shown in the figure.
In the circuit, the power circuit is composed of power transformer T, rectifier bridge UR, filter capacitors C4, C5 and three-terminal voltage regulator integrated circuit IC2; the infrared control circuit is composed of infrared light-emitting diode vLI, infrared photosensitive diode VLS, transistor V, resistors R1-R6, capacitors C1-C3, integrated circuit IC1, light-emitting diode VL2 and solid-state relay KN; the high voltage is composed of solid-state relay KN, resistor R7, capacitors C6, C7, diodes VD1, VD2 and high-voltage electrodes. After the AC 220V voltage is stepped down by T, rectified by UR, filtered by C5 and stabilized by IC2, it provides +6V working voltage for the infrared control circuit. The oscillation signal output by pin 5 of IC1 is amplified by V and drives VL1 to emit modulated infrared light. Usually (when no mouse enters the infrared detection area), V LS cannot receive the infrared light emitted by VLl, IC1 is in automatic oscillation state, its pin 8 outputs high level, VLZ is not lit, KN and high-voltage circuit do not work.
When a mouse enters the infrared detection range, the infrared light reflected by the mouse body is received by VD1, causing the 8th pin of IC1 to change from high level to low level, VL2 to light up, KN to work, and high voltage to kill the mouse. When the dead mouse is removed (the power supply should be cut off), VLS is cut off again, the 3rd pin of IC1 loses the input signal, the 8th pin becomes high level, V L2 is turned off, KN and the high voltage circuit stop working, and the circuit returns to the standby state.
Component Selection
R1-R6 use 1/4W metal film resistors or carbon film resistors; R7 uses 2W metal film resistors. C1-C4 use monolithic capacitors; C5 uses aluminum electrolytic capacitors with a withstand voltage of 25V; C6 and C7 use CBB capacitors with a withstand voltage of 1000V. VLS uses PH302 or BPW82 infrared photosensitive diodes; VD1 and VD2 use 1N4007 silicon rectifier diodes. VLl uses IR333 or SE303 infrared light-emitting diodes; VL2 uses 5mm ordinary light-emitting diodes. V uses 9013 or 3DG9013 silicon NPN transistors. IC1 uses LM567 or NE567 integrated circuits; IC2 uses LM7806 three-terminal voltage regulator integrated circuits. KN uses SP2110 or JGX-2F solid-state relays. High-voltage electrodes can be made of thinner bare metal wires or copper-clad plates.
This circuit is directly connected to the city, so you must pay attention to your own and others' personal safety.
- Share a solar beacon circuit
- How to connect TFT LCD to Raspberry Pi
- Homemade CNC plotter
- Satellite TV Set Top Box Remote Controller
- Automatic recovery electronic fuse with soft start function
- Infrared detection type electronic rodent killer circuit
- Working Principle and Production of TV Scanning Demonstrator
- Ultrasonic dog chaser made by NE555
- Input and output polarity reversal circuit composed of MAX660
- Detailed explanation of car battery charging circuit diagram
- Typical electronic rodent killer circuit diagram
- How does an optocoupler work? Introduction to the working principle and function of optocoupler
- 8050 transistor pin diagram and functions
- What is the circuit diagram of a TV power supply and how to repair it?
- Analyze common refrigerator control circuit diagrams and easily understand the working principle of refrigerators
- Hemisphere induction cooker circuit diagram, what you want is here
- Circuit design of mobile phone anti-theft alarm system using C8051F330 - alarm circuit diagram | alarm circuit diagram
- Humidity controller circuit design using NAND gate CD4011-humidity sensitive circuit
- Electronic sound-imitating mouse repellent circuit design - consumer electronics circuit diagram
- Three-digit display capacitance test meter circuit module design - photoelectric display circuit
