10 Examples of Classic Rectification Circuits
Source: InternetPublisher:刘德华河北分华 Keywords: Rectification circuit Updated: 2024/07/22
Figure 1 is the most classic circuit. Its advantage is that a filter capacitor can be connected in parallel to resistor R5. The resistor matching relationship is R1=R2, R4=R5=2R3; the gain can be adjusted by changing R5. The advantage of
Figure 2 is that there are fewer matching resistors, and only R1=R2 is required
. The advantage of Figure 3 is that the input impedance is high, and the matching resistors require R1=R2, R4=2R3.
The matching resistors of Figure 4 are all equal, and the gain can be changed by changing the resistor R1. The disadvantage is that in the negative half cycle of the input signal, the negative feedback of A1 is composed of two paths, one of which is R5, and the other is composed of the operational amplifier A2, which also has the disadvantages of the composite operational amplifier.
Figure 5 and Figure 6 It is required that R1=2R2=2R3, and the gain is 1/2. The disadvantage is that when the input signal is in the positive half cycle, the output impedance is relatively high. A common-mode amplifier with a gain of 2 can be added at the output for isolation. Another disadvantage is that the input impedance of the positive half cycle and the negative half cycle is not equal. It is required that the internal resistance of the input signal be ignored. In the
positive half cycle of Figure 7, D2 is on, and the gain = 1+(R2+R3)/R1; the negative half cycle gain = -R3/R2; the absolute value of the positive and negative half cycle gains is required to be equal. For example, if the gain is 2, R1=30K, R2=10K, and R3=20K can be selected.
The resistance matching relationship in Figure 8 is R1=R2.
Figure 9 requires R1 =R2, R4 can be used to adjust the gain, the gain is equal to 1+R4/R2; if R4=0, the gain is equal to 1; the disadvantage is that the input impedance of the positive and negative half-waves is not equal, requiring the internal resistance of the input signal to be small, otherwise the output waveform will be asymmetric.
Figure 10 is designed using the characteristics of the follower of a single-power amplifier. For a single-power amplifier, when the input signal is greater than 0, the output is a follower; when the input signal is less than 0, the output is 0. Be careful of the nonlinearity of the single-power amplifier when the signal is very small. Moreover, the single-power follower also has nonlinearity when a negative signal is input. In
the three circuits of Figures 7, 8, and 9, when the output of amplifier A1 When it is positive, the negative feedback of A1 is formed by a composite amplifier composed of diode D2 and operational amplifier A2. Due to the composite (product) effect of the two operational amplifiers, the gain of the loop may be too high, which is easy to produce oscillation.
There are some precision full-wave circuits that are not recorded, such as the high-impedance type. There is also a type that connects the in-phase input terminal of A2 to the inverting input terminal of A1. In fact, it is the same as the principle of this high-impedance type, so it is not specially included. Other types that use only one diode connected to the output of A1 are not included, because when this diode is cut off, A1 is in an open-loop state.
Conclusion:
Although there are ten kinds of precision full-wave circuits here, a careful analysis , I found that there are not many excellent ones, to be exact, there are only 3 types, which are the 3 types mentioned above.
Although the classic circuit in Figure 1 has many matching resistors, it can be completely realized with 6 equal value resistors R, among which resistor R3 can be connected in parallel with two R. The gain can be adjusted by R5, and the gain can be greater than 1 or less than 1. The most advantageous thing is that the capacitor filtering can be connected to R5.
The advantage of the circuit in Figure 2 is that there are fewer matching resistors, and only one pair of matching resistors is needed.
The advantage of Figure 3 is the high input impedance.
For the other types, some realize the negative feedback of A1 through the compound of A2 in the half cycle when D2 is turned on, which will cause self-excitation for some op amps. Some of the two half-waves have unequal input impedances, which places high demands on the signal source.
Although two single op amps can achieve the purpose of rectification, the input and output characteristics are very poor. Followers or in-phase amplifiers are required for input and output isolation.
Each circuit has its own design features. I hope we can learn useful things from the clever design of its circuit. For example, the design of a single-power full-wave circuit and a composite feedback circuit are both very useful design ideas and methods. If you can analyze the circuit principles of each figure and derive each formula, you will benefit.
- Causes and solutions for noise in digital Class D amplifiers
- What are the classifications of filters?
- What is the difference between CPLD and FPGA?
- Simple Wired Spy Bug Circuit Built Based on IC741
- Working principle/characteristics/application fields/equivalent circuit of unijunction transistor
- How to install the accelerometer
- What types of force sensors are there?
- Summary of knowledge points of multiplexer
- Introduction of TDA4863J/4863AJ TV field scanning IC
- Make a simple AM radio with digital circuit
- Three-phase controllable rectifier circuit a
- Odd voltage doubler rectifier circuit b
- Even-numbered voltage doubler full-wave rectifier circuit c
- Even-numbered voltage doubler full-wave rectifier circuit b
- voltage doubler rectifier circuit
- Bridge thyristor rectifier circuit schematic diagram
- Crystal diode single-phase half-wave resistive load rectifier circuit
- 22 commonly used diode single-phase rectifier circuits Figure 5
- 22 commonly used diode single-phase rectifier circuits Figure 1
