Make a simple AM radio with digital circuit
Source: InternetPublisher:国民男神经 Keywords: AM radio digital circuit Updated: 2024/11/06
Here is a simple radio circuit made of CMOS digital circuit CD4011, which has high radio sensitivity. CD4011 is a digital integrated circuit containing 4 NAND gates.
Principle: Usually, this type of NAND gate circuit is in two switching states, that is, outputting high level and low level. In fact, there is a transition zone in the conversion process between high and low levels, and the middle part of the transition zone is basically in a linear state. Therefore, the feedback circuit can be used to select the appropriate working state so that each NAND gate is in an amplified state.
The following is the electrical schematic diagram of the radio. L1 and C1 are the receiving resonant circuit, R1 is the DC negative feedback resistor, and C2 is the AC bypass. The received signal is amplified by gate A at high frequency, coupled by C3, and sent to the voltage doubler detection circuit composed of D1, D2, R2, and C4 for detection. It is further amplified by gates B, C, and D and sent to the headphone output. C1 in the figure can be selected as a single variable capacitor, and the coil L can be wound with 80-100T on a 50MM magnetic rod. High-impedance headphones should be selected for the headphones. You can also add a first-level integrated audio amplifier circuit such as LM386, or use a transistor for impedance transformation. By increasing and decreasing the number of turns of the coil on the magnetic rod, ensure that the radio is within the appropriate frequency reception range.
- How are diodes made using semiconductors?
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- What does a rectifier do? What is the process of rectification?
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- How does sand become chips?
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- How to calculate the value of capacitors in parallel?
- Working principle/advantages/disadvantages/size of optical fiber
- TL494 pin functions/configuration/ratings/operating conditions/layout diagram
- Digital number selection machine
- Do you know the difference between analog circuits and digital circuits?
- Summary of basic knowledge of analog and digital circuits
- Electronic potential circuit composed of digital circuits
- Digital circuit sound and light control stair delay switch circuit (6)
- Digital circuit sound and light control stair delay switch circuit (5)
- Touch-type delay circuit using digital circuits (5)
- Touch-type delay circuit using digital circuits (1)
- Delay light circuit using digital circuit (2)
- Improving digital circuits using photoconductive reflective elements
- 9V charger with digital circuit timer
