Y-△ started motor automatic mutual switching circuit a
Source: InternetPublisher:elleny Keywords: Motor BSP instrument Updated: 2021/07/02
(2) The Y-△ started motor automatic mutual switching circuit
circuit is shown in Figure 3-66.
This circuit can be used when electric contact instruments and other instruments are needed to measure a certain parameter (such as pressure, flow, temperature, etc.) during the transmission process of the substance .
In this circuit , when the electrical contact instrument
KP of the parameter measurement circuit reaches the lower limit (KP contact is disconnected and relay KAI is released), or when the running motor fails and the thermal
relay acts, the backup motor can be automatically put into service. The two motors can serve as backup for each other. The motor uses Y-△
to start.
- A simple magnetic switch circuit sharing
- Analysis of the working principle of car garage door lights
- Introduction to the internal structure of the Delta winding motor
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Methods for Eliminating Noise of Brushed DC Motors
- Design and analysis of wire control circuit
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- An experimental model of an infrared radio alarm
- Water supply reminder after water outage
- Car audio system anti-theft circuit
- Motor forward and reverse control wiring diagram (2)
- Set timing circuit when power is on
- strain sensor
- Agricultural temperature control circuit
- Fish farming thermostatic control circuit
- Junction field effect transistor mixer circuit
- Diode balanced amplitude modulation circuit
- Double gate field effect transistor high frequency amplifier circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Home appliance repair signal generator circuit
