Fan frequency speed regulation circuit realized by 555 timer
Source: InternetPublisher:奥特man123 Keywords: 555 Timer Updated: 2024/08/23
An electric fan simulation gust frequency speed regulation circuit can add a practical function to the old-fashioned fan.
Working principle:
The circuit is shown in Figure 1a. In the circuit, NE555 is connected as a square wave generator with adjustable duty cycle. The duty cycle can be changed by adjusting RW. During the period when the 3rd pin of NE555 outputs high level, the primary of the zero-crossing on-off optocoupler MOC3061 obtains about 10mA forward working current, which makes the internal GaSi infrared emitting diode emit infrared light, and turns on the photosensitive bidirectional switch in the zero-crossing detector when the mains passes zero, turning on the power supply of the electric fan motor, and the fan runs to deliver air. During the period when the 3rd pin of NE555 outputs low level, the bidirectional switch is turned off and the fan stops.
MOC3061 itself has a certain driving capability, and the operation of the electric fan motor can be controlled directly by using the internal bidirectional switch of MOC3061 without adding power driving components. RW is the duty cycle adjustment potentiometer, that is, the adjustment of the air supply time of the electric fan per unit time (the data of this circuit is about 20 seconds). Changing the value of C2 or the value of RW can change the control cycle.
The circuit in Figure 1b is a typical power expansion circuit of MOC3061. When controlling a motor with higher power, the power expansion circuit should be considered.
When making the circuit board, you can refer to the parameters in the figure to select the device. The power supply adopts the capacitor voltage drop method. Please pay attention to safety when making it yourself. It is forbidden for the human body to touch the circuit board directly.
- NE555 electronic windmill
- NE555 touch timer switch
- 555 lantern electronic switch circuit
- Four basic circuits of 555 monostable trigger
- 555 pyroelectric infrared sensing and lighting dual control delay energy-saving lamp circuit
- 555 rock lantern controller circuit
- 555 telephone recording additional circuit
- Water Activated Alarm
- 555 direct reading capacitance tester circuit
- 555 voice controlled lighting electronic wall clock circuit
- 555 Oscillator: Two Tone Generator Circuit Diagram
- Power delay turn-on circuit
- Multivibrator composed of 555 timer
- Conversion circuit diagram using LM555 timer
- 555 timer temperature sensor temperature control circuit
- NE555 time base integrated circuit diagram
- 50% duty cycle 555 circuit
- Self-stopping hypnotic device circuit diagram
- Double-key touch switch circuit diagram using 555 time base circuit
- Pulse width modulation circuit diagram based on 555 base time
