Conversion circuit diagram using LM555 timer
Source: InternetPublisher:张七岁 Keywords: Circuit diagram conversion circuit LM555 555 timer Updated: 2020/12/15
illustrate
Here is a very simple circuit schematic diagram of frequency (F and V) voltage conversion. Found this kind of circuit for digital frequency meter, this circuit is mainly based on a LM555 timer IC and is widely used in projects like tachometer and so on. The IC is wired in mono mode and converts the input frequency into a fixed pulse width, variable frequency PWM signal. Resistor R4 and capacitor C2 provide the necessary timing circuitry. Transistor T1 forms a discharge path in parallel to C2 which is necessary to trigger the IC again. Capacitor C1 acts as an input DC isolator.
Circuit diagram
![Frequency voltage<strong>conversion circuit</strong>](http://www.eeworld.com.cn/circuit/upload/cbd6ddcb214e3d0dae616dd11847949c/9a8e0f72446964ef34d6f0e993d2205a.png)
Precautions
This circuit can be assembled on Vero board.
Use 12V DC power supply circuit.
The LM555 must be installed in the holder.
The output of this circuit is not a pure DC, but a PWM waveform. Additional circuitry is required to convert pure DC to the PWM waveform.
- How are diodes made using semiconductors?
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- Causes and solutions for noise in digital Class D amplifiers
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- Working principle/advantages/disadvantages/size of optical fiber
- How to install the accelerometer
- Introduction of TDA4863J/4863AJ TV field scanning IC
- LED lights that “drain” battery power
- Digital number selection machine
- Introducing the CD4013 washing machine timer circuit diagram
- Ward call device circuit diagram
- Car power supply voltage monitoring circuit diagram
- Wireless frequency modulation (FM) microphone circuit diagram using Q5337
- Typical super regenerative radio receiver circuit diagram
- White noise electronic lullaby circuit diagram
- Two smartphone charging circuit diagrams
- Delayed AGC principle circuit diagram
- Regeneration receiving circuit diagram
- LED backlight driver module circuit diagram
