Solid state relay controlled forward and reverse starting circuit
Source: InternetPublisher:风向西瓜 Keywords: Solid state relay starting circuit relay control motor Updated: 2020/07/06
The solid state relay (SSR) is used as the electronic switch to control the
forward and reverse starting circuit of the motor , as shown in Figure 3-30. When the switch S is placed
in the "I" position, the motor rotates forward; when S is placed in the "II"
position, the motor rotates reversely. In the actual control circuit,
an inversion delay circuit needs to be set up to ensure the safety of the SSR. The delay is generally about 60~70ms.
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Car ice warning circuit sharing
- Use your smartphone to turn on/off the power in your home
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- How can we make the robot move precisely on a predefined path?
- What is a RADAX motor?
- Methods for Eliminating Noise of Brushed DC Motors
- Do-it-yourself trial production of phase failure protection device
- Audio interface protection circuit
- Ultra-short wave item left behind reminder alarm
- Frequency sensitive rheostat automatic forward and reverse starting circuit
- Frequency sensitive rheostat manual and automatic one-way starting circuit
- Frequency sensitive rheostat manual single phase starting circuit
- Manual Yanbian △-shaped step-down starting circuit
- Time relay controls auto-coupling step-down starting circuit
- The fourth Y-△ step-down starting circuit with arc flashover short circuit protection function
- Button control Y-△ step-down starting circuit 2
- Relay start circuit diagram
- Improved circuit of auto-decompression starting circuit
- Autotransformer step-down starting circuit
