Wiring b for changing a three-phase motor to a single-phase parallel capacitor
Source: InternetPublisher:aytwartoofyoroo Keywords: Wiring three-phase motor Updated: 2020/08/26
3) Changing the wiring of a three-phase motor to a single-phase parallel
capacitor
. Regardless of whether the windings are star-connected or delta-connected, they can be connected to single-phase by parallel capacitors. The wiring is
shown in Figure 3-19.
When starting, press button SB. When the motor reaches the rated speed, disconnect SB. In the figure, cg is the working
capacitance, C. is the starting capacitor . They can be estimated according to the following formula:
C. =Gui Curly: 亳cpF,; cn-c. ~4, Cc
in the formula j. ——Rated current of the motor, A;
U-rated voltage of the motor, V;
cosp-power factor, which can be 0.7~0.8 for small power motors.
- A simple magnetic switch circuit sharing
- Model rocket launch controller circuit
- Manual automatic air compressor control circuit
- Design and production of radio remote control fan stepless speed regulator
- Hydraulic control circuit design and analysis
- Design and analysis of voice control circuit
- Simple three-phase motor phase loss protection circuit
- Magnetic door and window anti-theft alarm
- Homemade short circuit alarm device
- Vibration anti-theft alarm circuit
- Inspection circuit diagram for broken rotor bar of three-phase motor
- Three-phase motor phase failure transistor protection circuit
- Anti-interference wiring of DC circuit of electronic equipment
- Lightning protection wiring for 300 to 1500kW direct-match generator b
- Wiring of lightning protection network on the roof of a multi-story residential building
- Coordinating wiring between leakage protector and fuse, isolating switch and circuit breakerb
- Current type three-phase motor phase failure protection circuit
- Conversion of delta connection three-phase motor to single-phase operation circuit
- Star-delta starting three-phase motor stall protection circuit
- Three-phase motor phase failure protection circuit
