Anti-interference wiring of DC circuit of electronic equipment
Source: InternetPublisher:消失的歌 Keywords: Anti-interference wiring electronic equipment Updated: 2021/10/28
Adding anti-interference capacitors to the input side of the DC power supply of electronic equipment
can suppress interference from the DC power supply. Its
wiring is shown in the figure.
In the figure, capacitors Cl and cz are used to resist high-frequency interference
, and C3 is used to resist low-frequency interference. Ri and R2 are
the voltage-reducing resistors of the voltage stabilizing circuit and can also play an anti-interference role
. CI - generally takes 0.22 ~ lyF/400V, C2 -
generally takes 0.1 ~ 0. 47_uF/50V, C3 - generally takes
100 ~ 500pF/50V; voltage regulator tubes vsl and VS2 are selected according to the working power supply voltage of the electronic equipment .
- Analysis of the working principle of switching regulator
- Build a simple buck-boost regulator and test it on a breadboard
- Step-down power supply for driving relays
- Driving circuit that controls LED brightness using PWM signal
- Detailed explanation of 5v charger circuit diagram
- Electric bicycle battery charger circuit
- Adjustable voltage regulated power supply circuit
- A low-cost, high-reliability battery charger for electric vehicles
- Detailed explanation of mobile phone charger circuit diagram
- Homemade home inverter circuit diagram
- Wiring circuit of three-phase three-wire active energy meter with current transformer
- Three-phase four-wire active energy meter direct-entry wiring diagram
- Wiring of automated instruments against common mode interference
- Three types of wiring for isolation layer of isolation transformer
- Wiring of lightning protection belts, voltage equalizing rings, etc. in high-rise buildings
- Coordinating wiring between leakage protector and fuse, isolating switch and circuit breaker c
- Wiring f when leakage protector supplies power to single-phase load in TN system
- Wiring c when the leakage protector in the TN system supplies a three-phase balanced load
- Wiring a when the leakage protector in the TT system supplies a three-phase balanced load
- Suspended anti-interference circuit
