Solder spot measuring instrument circuit
Source: InternetPublisher:同住地球村 Keywords: measuring instrument BSP instrument Updated: 2020/07/05
The quality of solder joints is the key to electronic production; in addition to general inspections, it is best to use instruments for measurement and inspection.
The solder joint measuring instrument can be used to measure whether the welding quality meets the requirements and check whether the circuit is connected. When the solder joint resistance is less than 1S1, the instrument
makes a sound. When the circuit is open or the value is above 10, the instrument will not fire. A sound is produced,
as shown in Figure 5-11.
The operational amplifier VA741 (LM324) is made into a general differential amplifier
. When the test probes A and B do not touch the test points,
the voltage drop causes the output of the operational amplifier to be negative and the buzzer does not make a sound; otherwise , when
the resistance at both ends of the probe is less than lfl, the potential of the non-inverting terminal is higher than that of the inverting terminal, and the operational
amplifier outputs a positive voltage. The oscillator composed of 104093 and other components
works, and the audio voltage signal generated makes the hummer make sound. RP1 is
a potentiometer used to adjust the pronunciation. RP2 is used to adjust the volume.
- Lightweight and practical multi-core cable detection circuit
- Simple and easy to make zero degree detector
- Homemade simple magnetic material tester
- NE555 makes a simple and practical acupoint detector
- Fire detector made with photodiode
- 4-range digital voltmeter circuit using ADD3701
- A low-cost inductance meter consisting of a single IC
- AC equivalent amplifier circuit
- High resistance DC differential amplifier circuit
- DS8 type 100V, 5A mutual inductance three-phase three-wire electric meter wiring
- Motor forward and reverse control wiring diagram (2)
- Set timing circuit when power is on
- Excellent performance household inverter power supply circuit
- Agricultural temperature control circuit
- Straw returning to field crusher circuit
- Biogas concentration detection line
- DC ammeter
- collector amplitude modulation circuit
- superheterodyne radio circuit
- Home appliance repair signal generator circuit
