Power meter wiring circuit
Source: InternetPublisher:睡不醒的小壮 Keywords: wiring Updated: 2021/11/29
The power meter should have at least four terminals: two current terminals and two voltage terminals. One current terminal and one voltage terminal are marked with
a "*" or "+" sign. They are called current coil and voltage terminals. The "same polarity end" of the coil. According to national standards. : The symbol of the power meter is
a horizontal thick solid line (representing the current coil) and a vertical thin line (representing the voltage coil) within a circle.
Wiring rules: The current coil end is connected in series with the load under test, and the voltage coil end is connected in parallel with the load under test; the "*" end of the current terminal button and the
"*" end of the voltage terminal button must be connected to the same polarity of the voltage; if " When the x" terminal is both the inflow terminal of the current and voltage coil currents (in the case of AC
, the phase difference is less than or equal to 90") or the outflow terminal, the pointer of the power meter deflects forward, and vice versa. Therefore, " *"The cross is called
the "generator end". The choice of wiring method.' Among the four wiring
methods
shown in Figure 5-9 , a and c are "voltage branch front connection", while b and d are "voltage branch front connection"
The difference between them is that
the method error is different. In general, the power consumption of the current coil is smaller than that of the voltage coil branch, so the voltage branch
is generally connected before the branch .
- Make a Simple Darkness Detector Circuit
- Homemade Metal Detector
- How to Simplify Analog Front-End Design for Heart Rate Monitors
- Design of blood analyzer
- Temperature-frequency conversion circuit composed of CD4046
- Typical two-stage low-pass filter circuit
- High-speed gain programmable amplifier circuit
- Phase sequence indicator circuit diagram
- Temperature voltage conversion circuit
- Numerical control following or inverting circuit
- Temporary power lines
- Radial wiring power supply circuit c
- Radial wiring power supply circuit a
- PLC input and output wiring a
- Lightning protection wiring for direct-match generators of 300kW and below b
- Computer system professional ground wire and dedicated conversion socket wiring
- Wiring d when leakage protector supplies power to single-phase load in TN system
- Wiring c when the leakage protector in the TN system supplies a three-phase balanced load
- Wiring b when leakage protector in TT system supplies single-phase load
- Three-phase four-wire active energy meter Y-shaped connection
