Wiring c when the leakage protector in the TN system supplies a three-phase balanced load
Source: InternetPublisher:黄土马家 Keywords: Wiring leakage protector BSP Updated: 2021/10/07
TN system, that is, the neutral point on the power side is directly grounded.
In the figure, the TN-C system is a three-phase four-wire system in which the working neutral line N and the protective neutral line PE are combined into a PEN line; the TN-S system neutral line N cannot be connected to the neutral of
other equipment or lines without leakage protectors. Line N is shared and is not allowed to be connected to the protective neutral line
PE, equipment metal shells, wire steel pipes and other metal parts connected to the earth . That is to say,
a system with three phase lines, a general neutral line N and a protective neutral line PE (PE is led separately from the neutral point of the transformer) through the leakage system
is also called a five-wire system.
- A very convenient small power supply circuit to share
- Schematic diagram of car cigarette lighter to USB power port
- Using Lead-acid Battery as Power Source for Walkman
- Fabrication of multi-cell lithium battery charging circuit
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Current/voltage conversion circuit using current converter
- A small and easy-to-make fast charger
- 0.7~24V continuously adjustable current limiting power supply
- Constant current charger using light emitting diode as voltage regulator
- The production of adjustable voltage-stabilized power supply composed of LM317
- Electronic anti-asthma circuit
- High-efficiency speaker circuit for rural stage
- Straw returning to field crusher circuit
- Agricultural spraying and insecticide control circuit
- Farmland irrigation automatic control circuit a
- Domestic KD8041 integrated phase locked loop
- Mixer built with analog multipliers
- Amplitude modulation circuit composed of MC1496
- Broadband high frequency power amplifier circuit
- Digital stopwatch display circuit
