Computer system professional ground wire and dedicated conversion socket wiring
Source: InternetPublisher:天天都吃好吃的 Keywords: wiring socket computer system ground Updated: 2021/03/26
In order to prevent static electricity from causing harm to the computer system , grounding work should be done carefully and a special grounding device should be installed, that is,
a special grounding device should be added to the protective zero connection system. The wiring of the dedicated ground wire and dedicated conversion socket is as shown in the figure. The grounding
resistance should not be greater than 10.
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Parallel DC regulated power supply circuit diagram
- Dual forward converter schematic diagram
- Constant current charger using light emitting diode as voltage regulator
- Converting a lithium battery charging board into a constant voltage and current charger
- A low-cost, high-reliability battery charger for electric vehicles
- Homemade home inverter circuit diagram
- Wiring schematic diagram of a factory's secondary low-voltage power distribution panel
- A cascade amplifier consisting of a grounded source and common base amplifier
- Combination of grounded source and common emitter amplifier
- BX2-500 arc welding machine remote control circuit wiring
- Wiring of the power supply part of the microcontroller
- Wiring of zinc oxide arrester b
- Lightning protection wiring of phase-shifting capacitor on pole a
- Lightning protection wiring b for the substation incoming line section with 6 to 35kV cable incoming lines b
- Making an entry-level tube amp
- High current NOT gate driving a grounded load
