Double button switch circuit diagram explanation
Source: InternetPublisher:狂妄火龙果 Keywords: Switch circuit push button switch Updated: 2024/07/12
This is a two-button electronic switch, let's see how it works.
When the power is turned on, both transistors are in the cut-off state, and the circuit is blocked, which is equivalent to a closed switch.
When the ON button is pressed, the NPN transistor obtains bias current and turns on. After the voltage is loaded to the load, a voltage is generated at both ends of RL. This voltage causes the PNP transistor to turn on and provide bias current to the NPN transistor, forming an interlock. When the ON button is released, the circuit remains on, allowing the load to continue working.
Press the OFF button, the PNP transistor is turned off, and the NPN transistor is also turned off due to the loss of bias current, and the circuit is closed.
It can be seen that this electronic switch will reduce the operating voltage of the load by about 1V, and RL needs to be set according to the load current. The maximum current that the electronic switch can withstand depends on the resistor RL and the NPN transistor.
- How to build a soldering iron heat controller circuit using microwave parts?
- Design and selection of electric control valve system drive
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- How to choose the right level of integration to meet motor design requirements?
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Simple phase failure protection circuit composed of intermediate relay
- Design and principle analysis of practical electric curtain remote control device
- Home wireless burglar alarm circuit
- Night dog barking anti-theft reminder circuit
- Analog multi-way switch expansion circuit
- Ultrasonic remote control lighting switch circuit b
- Ultrasonic remote control lighting switch circuit a
- Photoelectric control switch circuit
- Automatic periodic switching circuit 4
- Contactless proximity switch circuit 2
- Lighting sound-activated switch circuit using thyristors Part 2
- Touch lighting switch circuit three
- One of the touch lighting switch circuits
- Sub-ultrasonic remote control light switch circuit (2)
