Ultrasonic remote control lighting switch circuit b
Source: InternetPublisher:containsmachine Keywords: switching circuit ultrasonic remote control Updated: 2020/03/23
Ultrasonic transmitter circuit composed of T-40-16 and 555.
As shown in Figure a, the circuit consists of ultrasonic transmitter T-40-16 and 555 circuit. Adjusting the potentiometer RP can change the oscillation
frequency of the circuit. The 40kHz oscillation pulse output from pin 3 of the 555 drives the T-40-16 to work, causing it to emit a 40kHz ultrasonic signal. The working voltage of the circuit
is 9V, and the working current is 40-45mA. The control distance is greater than 8m.
(2) The R-40-16 ultrasonic wave receiving circuit
is shown in Figure 18-32b. The circuit consists of VT1-VT7 and other components. Since the signal received from the transmitter is very weak, the circuit uses
multi-stage amplification to output a square pulse signal, which is connected to VT5: VT6 and related components to form a bistable circuit. i. The transistor
VT4 is turned on every time Once (the transmitter transmits once), the trigger signal sends a trigger pulse to the bistable circuit via G and C. VT5:''VT6
reverses once. When VT6 changes from cut-off to on, VT5 and VT7 cut off, and relay K releases and holds. When the next pulse arrives
- VT6 turns on and turns off. VT7 is turned on and relay K is closed to control the load operation. This circuit can be used for remote control of various electrical switches
- Why does CAN FD communication need to enable TDC for sending and receiving delay compensation? How to configure TDC and SSP in TCAN4550?
- How to use CAN protocol in Arduino
- Production of a FM wireless microphone
- MCl3175/MCl3176 FM/AM 928~902 MHz/470~260 MHz Transmitter
- SB-200BRX superheterodyne receiving circuit
- R5 433.92 MHz Receiver Module
- GPS RF front-end circuit composed of MX2740
- XE1203 FSK 915/868/433 MHz Transceiver
- RF2926 AM/FMASK/FSK/OOK 915/ 868/433 MHz Dual Conversion Transceiver
- RXM-433/418/315-LC-P AM Receiver Module
- Photoelectric control switch circuit
- Sound control power saving switch circuit
- Sound remote control switch circuit
- JK7 proximity switch circuit
- Gas-sensitive alarm circuit 2
- Contactless proximity switch circuit 2
- Thyristor AC switch circuit 3b
- Thyristor AC switch circuit 3a
- Touch lighting switch circuit four
- One of the fade-in and fade-out light switch circuits
