Detailed explanation of the circuit diagram of the sound effect generator based on UM3561
Source: InternetPublisher:newlandmark Keywords: Generator circuit sound effect Updated: 2024/07/12
illustrate:
This circuit uses UM3561IC to produce four different sound effects.
Circuit Diagram
Notes:
There is nothing complicated here. All sound effects are generated by the IC, which is amplified by the transistor at pin 3 and drives the speaker. A 56 ohm resistor and 8 ohm speaker can be replaced by a 64 ohm speaker.
2 pole 4 way switch controls sound effects. Position 1 (drawn) is a siren, position 2 is a fire truck sound, 3 is an ambulance and position 4 is a machine gun effect. This IC has been discontinued.
- The easy production of several top-quality tube preamplifiers
- Design of a tube amplifier that uses the mains electricity to directly provide screen working power
- The production of 6P14 small tube amplifier
- Stereo phono amplifier circuit with bass control composed of LM1877
- Volume synchronization circuit constructed with discrete components
- LM4902 differential input audio amplifier circuit
- A common-phase audio power amplifier circuit powered by a split power supply using LM1877
- Auxiliary audio power amplifier circuit using LM4732
- LM4915 is used for dual-channel amplifier circuit
- American Grado RA1 headphone amplifier
- square wave generator circuit
- Staircase wave signal generator circuit
- Sawtooth wave generator circuit
- Pulse function generator circuit with very large (or very small) duty cycle
- Function generator circuit using 8038
- Multi-channel frequency shift keying generator circuit using XR-2207
- Low voltage DC power supply negative ion generator circuit diagram
- High-precision nanoamp level current generator circuit diagram
- Simple multifunctional signal generator circuit
