Fire pump (one in use and one in standby) soft start control circuit a
Source: InternetPublisher:笑流年 Keywords: control circuit soft start start control Updated: 2020/03/19
The soft start control circuit of the fire pump (one in use and one in standby) using FSR1000X soft starter is shown in Figure 5-26. When the transfer
switch 1SA is placed in the automatic position, one of the two fire pumps is running and the other is in standby. The two pumps are standby for each other
. After an operation failure, the standby pump is automatically put into operation immediately. When 1SA is placed in the manual position, both pumps can be operated manually and independently. The time relay
(KT) delay setting value is greater than the soft start time of a single unit.
In the figure, 1 and 2 are bypass relay terminals ; 3 and 4 are fault output terminals; 7 is instantaneous stop input terminal; 8 is soft stop input
terminal; 9 is soft start input terminal; 10 is common contact input terminal (COM ); Il is the ground terminal (PE);
12 and 13 are the control power input terminals .
- Interpretation of CAN bus driving recorder system circuit
- Smart Farm Design Solution Based on LoRa
- What components and functions does the battery management system consist of?
- One control two constant pressure water supply frequency conversion speed control circuit b
- One control three constant pressure water supply frequency conversion speed control circuit a
- RF leak detector circuit diagram
- Remote control fan speed regulator circuit
- Commonly used oil pump motor control circuits for presses
- Slow logic pulse listener circuit diagram
- Human body approaching safety protection warning circuit
- time control circuit
- Stapler control circuit
- sound control circuit
- CPU input and output and memory control circuit
- Digital current loop control circuit
- Neon light control circuit
- Automatic sprinkler irrigation control circuit
- Electric heater temperature detection control circuit
- Fire pump (one in use and one in standby) soft start control circuit a
- Auto-decompression starting control circuit
