Electric heater temperature detection control circuit
Source: InternetPublisher:偷熊计划 Keywords: Control circuit temperature detection BSP Updated: 2021/05/26
Shown is a common electric heater temperature detection control circuit. The circuit is mainly composed of a power supply circuit and a temperature detection control circuit
In the circuit, the power circuit is mainly composed of the AC input part, power switch K, step-down transformer T, bridge rectifier circuit (VD1-VD4),
resistor Ri, power indicator light VD1, filter capacitor cl and Zener diode VS1. The temperature detection circuit is composed of the thermistor
RT, integrated circuit IC (NE555), potentiometers RP1 ~ RP3, relay K, light-emitting diode VD2 and peripheral related components.
The AC 220 V voltage is stepped down by the transformer T, rectified by the bridge rectifier circuit, filtered by the capacitor, and stabilized by the diode to produce a DC
voltage of about 12 V, which provides the operating voltage for the integrated circuit IC. When the circuit detects that the ambient temperature is low, the resistance value of the thermistor RT becomes larger, the
voltage of pins ② and ⑥ of the integrated circuit IC decreases, pin ③ outputs high level, VD2 lights up, and relay K draws electricity.
When the ambient temperature rises to a certain temperature, the resistance value of RT becomes smaller, and the ② pin of the
integrated circuit IC , The @ pin voltage increases, @ pin outputs low level, VD2 goes out, relay K is released, and its normally open contact
cuts off the working power of the electric heater, causing the ambient temperature to gradually drop.
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- What are the parts of the fpga design process
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- Important things to know about PCB routing and how to design the right routing for your PCB
- Make a simple AM radio with digital circuit
- Star finder battery indicator circuit
- LED lights that “drain” battery power
- LED Night Light
- FL52C4 induction electronic greeter
- stuttering correction circuit
- Electronic anti-asthma circuit
- Particle clogging alarm circuit of wheat seeder
- Proportional frequency discriminator circuit
- Diode balanced amplitude modulation circuit
- Series crystal oscillator
- Broadband high frequency power amplifier circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- OTL low frequency power amplifier circuit
- Power phase sequence display circuit
